Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
Questions au sujet de 722 Voir tout
No EFI Boot for Dual Boot Linux after replacing SSD
I changed my SSD on my MacBook Pro and installed Montery.
Today I tried to install Ubuntu dualboot but there is no EFI.
What did I wrong?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
I’ve heard issues with newer macOS this can happen as the virgin drive which is setup with High Sierra or newer which sets up a very different drive structure that the older Sierra macOS. Basically, this is related to the change from HPS+ to APFS file system.
So… if you had upgraded the remanence of he old would still be present.
You’ll need to reformat the drive removing all partitions, install Sierra in one partition then install Ubuntu in a second partition. You should be able to jump between using the onboard Startup Manager using the boot-up smart key service pressing the Option key.
Then you should be able to upgrade to Monterey and then use the Ubuntu dual boot option.
Indice 0
Ajouter une réponse
Marv sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 42
