blink 5 times on power on - no image
Hi, I'm trying to fix my tv UE46EH6030,
He blink 6 times and the screen keep black.
I opened the tv, all the condensators and diodes are ok. But... I have no power on the led connector.
When I use the remote control, the led goes on and off (this part is correctly powered), and when the tv is "on", I measure 200v on the MKP condensator near the led strip connector, but nothing on the connector itself (even with led strip unplugged).
I can't find broken IC or condensator
Other side:
Any idea ?
Update (12/17/2022)
Hello, so, actually the symptoms are :
- When I plug the power (main board + backlight connected) => The red led blink, but I can toggle the led with the remote control. Backlight do not power on. ( mainboard seems to be correctly powered )
- When I plug the power (main board disconnected + backlight connected) => the backlight do not power on
What I troubleshooted:
- All the CAPS & Diodes on the mainboard (good shape, and tested with multimeter).
- With MB + Backlight connected, when the TV is standby (red led ON) : the purple part (see picture) is not powered.
- With MB + Backlight connected, when the TV is "on" (red led OFF) : the purple part is powered (185V on cap's) but no voltage on the backlight connector (top white connector).
I didn't test the led strip themself, ... but as I have no voltage on the connector, the led are probably not the root cause ( wrong ?)
To investigate further, I need a schematic of the board. What can be the issue ? a kind of pwm transistor / mosfet dead ? ... how can I investigate this. The board is a BN44-00552a ( common on Samsung XXEH-6030 models; from 40 ; 46 inches ) and not so easy to find for a decent price ... (almost the price of a similar TV ...)
This is the other side of the backlight power part of the powerboard. I can't read the partnumbers and without schematics, I can't troubleshoot this :-(
Thanks.
