Need help to find LCD display replacement. Refmate-4
Hi!
I work in hvac and recently got a new digital manifold named Refmate-4.
Sadly the display broke from pressure while it was inside the box that comes with it. Half of the display is now unreadable, making it useless for work.
I have disassembled the manifold and found the the following number on the back of the display, DLC04430BCM10RT-B-3
Is it possible to find the same display so i can repair it?
@hvac123 post another picture that show the rest of the numbers. The sticker may only be for internal use by the reseller.
par oldturkey03
I added two pictures with more numbers. The numbers on the sticker tells me the manufacturer of the display. Its TLC and the display is 4.3". Sadly i cant find the exact display for sale. Could it be possible to use one from another manufacturer?
par Steve
@hvac123
To use another LCD it would have to be wired the same way as the one you have i.e. same wire pinout connection in both displays
Maybe try contacting the manufacturer of the manifold and ask them if it is available as a spare or if they can tell you the part number from the display manufacturer.
par jayeff
@hvac123 okay so the LCD is made by DLC Display Co. https://www.dlcdisplay.com/ and the part number is actually the one on the label DLC0430BCM10RT-B-3. It is a 4.3 inch LCD screen. So now let's see if Alibaba or Taobao can be of more assistance.
par oldturkey03
Thanks for the help!
I have contacted the manufacturer of the manifold, a Swiss firm. I will hopefully get an answer after the weekend.
I couldnt find the same dlc display from the serialnumber so I thought someone might tell me if it was possible to buy from another manufacturer.
But if i find any 4.3 inch screen with the same type of wire pinout, should it work?
par Steve
Afficher 1 commentaire en plus
