Aller au contenu principal
The Meta Quest 2 (formerly Oculus Quest 2) is the successor to the Oculus Quest that came out on May 21st, 2019. The Quest 2 is a revised model that features a better processor and redesigned touch controllers.
Questions au sujet de 113 Voir tout
Broken ring/halo ribbon assembly inside torn in half
Son broke his halo/ring, ribbon assembly that surrounds and connects everything inside ring is torn in half. My question is how can I find a list of internal parts to replace items like this? I cannot even find a diagram or schematics. That's all I really need then I can figure it out. Thanks in advance
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
@swankyjrsgurl lets see what you got going on there. Post some pictures with your QUESTION. That way we can see what you see Ajout d'images à une question existante
par
Ajouter un commentaire
2 Réponses
Solution retenue
You would need another quest 2 controller or if you can find it, parts. Schematics for a controller are hard to find, like with my quest 1 I broke both the controllers plastic ring because there is no documentation. my suggestion - if its already broken, try to fix it, but be careful not to break anything else. If you have no expeirence and there is someone around you who is learning or practicing, let them look at it. You could also ask on reddit or ask for someone to do it for you if you pay.
Indice 1
1 commentaire:
Thank you very much for your response. I have a lot of experience with fixing electronics, I was a micro/mini solder tech in the Navy (it was my favorite job lol) I've taken it apart and checked out the damage, I found replacement ribbons but I just wasn't sure. I'm definitely not going to go in with possible parts so thank you. I kind of figured they wouldn't be easy to come by. Lol
par
Where did you find the replacement ribbon for the halo/ring? I can't find it anywhere.
Indice 0
Ajouter une réponse
Jewel S sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 30
Total : 152
