Aller au contenu principal
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Questions au sujet de 34 Voir tout
HTC 10 Fpc connector problem
Hi, I have a HTC 10 that I changed its battery because the previous one got swollen and cause the screen to break and I haven't tried it till I got a replacement battery.
When I've plugged the new battery I tried testing the phone it does turn on but a black screen and the tactile works normally, After some diagnosis on the motherboard I've noticed that the fpc connector is broken and one of the upper pins was ripped.
Is the damage on the fpc connector causing the screen to stay black or should I just get a new screen replacement?
or can I make contact between the pin and the screen ribbon without changing the fpc connector?
Looking forward to hear your suggestions.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Ideally you'd need both, the connector won't be putting the correct pressure on the cable and the screen could of gone completely.
Indice 2
1 commentaire:
I did try bridge the pins with the corresponding area on the ribbon cable and it worked normally so I need to replace the connector I guess.
Thanks for the answer sir.
par
Ajouter une réponse
houcine sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 30
