Plus d'arrivé d'eau dans mon lave vaisselle
Lorsque je lance un programme, celui-ci se lance mais l'eau n'arrive jamais.. merci de votre aide
monia verchere sound like an issue with the water inlet valve or the pump. Let us know what exact model your Bosch Dishwasher is. Of course, you did check the water supply to make sure it was turned on and that you do have water going to the dishwasher.
Translation
monia verchere semble être un problème avec la valve d'entrée d'eau ou la pompe. Faites-nous savoir quel est le modèle exact de votre lave-vaisselle Bosch. Bien sûr, vous avez vérifié l'alimentation en eau pour vous assurer qu'elle est ouverte et que l'eau arrive bien au lave-vaisselle.
Water not running in
Problem
Filters in the water connection of the supply or AquaStop hose are blocked
Solution
Clean the filters in the water supply hose. Attention: AquaStop safety device contains an electric valve, do not immerse in water. Instructions: 1. Turn the tap off. 2. Take the hose off the tap. 3. Clean the filters using a small brush. 4. In the case of appliances without an AquaStop, also remove the hose from the back of the appliance. Take out the filter with pliers and clean it. 5. Reconnect the hose and check it for leaks.
Problem
Supply hose is kinked
Solution
Ensure that the supply hose is installed without kinks.
Problem
Tap is jammed or limescaled and this causes low water pressure
Solution
Check the water pressure directly on the tap using a bucket. Approximately 2.5 gallons (10 liters) of water per minute must flow out of the fully opened tap. Contact your plumber if the water pressure is too low.
The part to definitely check is where the float etc. are located. I attached some directions but those are not specific to your dishwasher. Same principle, different model.
It is not all that complicated but requires some disassembly. Take your time and I am sure you are going to fix it again.
Repair is War on Entropy.
Translation
L'eau ne coule pas
Problème
Les filtres du raccord d'eau du tuyau d'alimentation ou du tuyau AquaStop sont obstrués.
Solution : nettoyer les filtres du tuyau d'alimentation en eau.
Nettoyez les filtres du tuyau d'alimentation en eau. Attention : Le dispositif de sécurité AquaStop contient une valve électrique, ne pas l'immerger dans l'eau. Instructions : 1. Fermer le robinet. 2. Retirer le tuyau du robinet. 3. Nettoyez les filtres à l'aide d'une petite brosse. 4. Pour les appareils sans AquaStop, retirez également le tuyau à l'arrière de l'appareil. Retirez le filtre à l'aide d'une pince et nettoyez-le. 5. Rebranchez le tuyau et vérifiez qu'il n'y a pas de fuite.
Problème
Le tuyau d'alimentation est plié
Solution : Vérifiez que le tuyau d'alimentation n'est pas plié.
Veillez à ce que le tuyau d'alimentation soit installé sans pli.
Problème
Le robinet est bloqué ou entartré, ce qui entraîne une faible pression d'eau.
Solution : Vérifiez la pression de l'eau directement sur le robinet en utilisant un seau.
Vérifiez la pression de l'eau directement sur le robinet à l'aide d'un seau. Environ 10 litres d'eau par minute doivent s'écouler du robinet complètement ouvert. Contactez votre plombier si la pression de l'eau est trop faible.
La partie à vérifier absolument est l'emplacement du flotteur, etc. J'ai joint quelques instructions, mais elles ne sont pas spécifiques à votre lave-vaisselle. Même principe, modèle différent.
Ce n'est pas très compliqué, mais cela nécessite un certain démontage. Prenez votre temps et je suis sûr que vous le réparerez à nouveau.
La réparation est la guerre contre l'entropie.
Bonjour, merci de votre réponse.
Oui j'ai vérifié l'alimentation d'eau. 🙂
La référence de mon lave vaisselle bosh est le : SGS45M12EEX/56
encore un grand pour votre aide
Vérifiez ou faites vérifier :
Cordialement
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 121
