@juliettena29898 For now, you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using [Apple iPhone] these guides. Since you did not tell us the exact model of iPhone, you will have to choose which guide will apply to your phone. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a iPhone 3G, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Until it is cleaned, everything will only be a guess. It is possible that a simple LCD replacement will fix this issue.
Translation
Pour l'instant, vous devez cesser d'essayer de charger, de synchroniser ou d'utiliser votre téléphone. Cela risque d'aggraver une situation déjà difficile. Cela risque d'endommager davantage votre téléphone.
La prochaine chose à faire est de le nettoyer. Démontez votre téléphone en suivant ces guides [Apple iPhone]. Comme vous ne nous avez pas indiqué le modèle exact de l'iPhone, vous devrez choisir le guide qui s'applique à votre téléphone. Vous devez retirer toutes les protections EMI. Si vous ne les retirez pas, autant ne rien faire. Après les avoir enlevés, nettoyez toute la carte, les connecteurs et tout le reste avec de l'alcool isopropylique à +90%. Suivez le ce guide, et même s'il a été écrit pour un iPhone 3G, tous les points sont pertinents pour votre téléphone. Pendant que vous nettoyez votre carte, vérifiez qu'il n'y a pas de dommages évidents, comme des composants brûlés ou manquants, etc. Une fois la carte correctement nettoyée, remplacez la batterie. Toutes ces étapes ont pour but d'éviter une défaillance tardive due à la corrosion. La meilleure chose à faire est de nettoyer la carte avec un nettoyeur à ultrasons, mais si vous n'avez pas accès à un tel appareil, ceci peut au moins vous aider. Une fois que tout cela est fait, réassemblez votre téléphone et réévaluez-le. Malgré tout, les dommages causés par l'eau n'ont qu'une faible chance d'être entièrement réparés, mais vous pouvez au moins essayer.
Tant qu'il n'est pas nettoyé, tout n'est que supposition. Il est possible qu'un simple remplacement de l'écran LCD permette de résoudre le problème.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
