Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
1500 questions Voir tout
Why is the home button, sound and computer detect link failed?
the phone was dropped, from the outside the appearance is untarnished but obviously something went wrong inside, it now fails to read when i insert the charger(battery is failing) and the home button wont work either...not only this but sound is failing too...both the earphone dock and the speaker?...would i be better off just buying a new phone or is it fixable??
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
it's definitely fixable. You would need to open the phone and check that connector no.4 is on, this controls all of those functions. If you reconnect that and you still have none of the functions then the dock connector will need replacing. I think this is a simple case of a loose connection so you won't need to spend a whole lot of money.This has a handy video to watch that shows you how to open the phone and get to the dock/replace dock. iPhone 3GS Dock Connector
Image iPhone 3GS Dock Connector
Produit
$19.99
Indice 1
1 commentaire:
thank you kindly..ill check that out and hopefully get fixed up
par
Ajouter une réponse
rachel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 556
