Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,3 GHz, 2,6 GHz ou 2,7 GHz (Turbo Boost jusqu'à 3,7 GHz) avec 6 Mo de cache L3 partagé.
561 questions Voir tout
Replaced left speaker but now screen is black
I replaced the left speaker in my MacBook Pro and had to remove the motherboard in order to do that. After finishing and putting computer back together, when I turned on the computer my screen is black but I can hear the startup sound
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Using a flashlight shine it into the lids Apple logo (a poor man’s backlight), do you see a faint image of your desktop and its icons?
Indice 1
6 commentaires:
No, I unfortunately see nothing when doing that.
par
@michaelaspeaks - So the video signal is not reaching the display then. Check the displays LVDS cable and the logic board connector for damage.
par
I think you’re right, it might be the lvds cable. It looks like two prongs got bent when I initially put it back together.
par
@mspeaks57 - These are easy to damage. Now you have to replace the cable which will require taking off the display and replacing the cable MacBook Pro Retina (2012-2015) Display LVDS Cable follow this guide Remplacement de l'écran complet du MacBook Pro 15" Retina mi-2012 focus on Step 4 in this MacBook Pro Retina Display Teardown you only need to get to the connector on the T-CON board.
par
Thank you! Just need to get the cable now
par
Afficher 1 commentaire en plus
Ajouter une réponse
Mspeaks57 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 45
