Why driver window doesn't work?
Driver window doesn't work. All other windows work even from the driver door just not driver window. It doesn't make any kind of noise or anything when I try to put it down it's stuck up. Could it be the motor or the switch?
Unless you have access to wiring diagrams, you can try removing the door card, locate the power unit and try powering it directly from the battery or use another 12v battery. Powering the window unit will either result in the motor operation or not to determine whether the master window switch or the power window unit failed. There's also a possibility of wiring damage, flexing of wire harness by the door hinge. If you're familiar with using a multimeter, measuring for power output from the driver's window switch and window power unit terminals can help.
par F Dryer
