Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
My mac wont run any software
I have a mac that has both macos and windows, and it was working perfectly fine until yesterday. The battery died, and when It finally turned on, the windows software cant get past the "automatic repair" screen, anything i tried just turns off and starts again in this screen. The macos software is no better, just starts up and turns off in the middle of the loading screen. Im sorry if its difficult to read english its not my first language. Can someone help me, i really need this laptop!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Dual partitioned drives can be difficult to fix as you need to run the tools from a second physical drive.
Do you have access to a second Mac system to create a bootable USB-C thumb drive?
Get a 32GB drive and using the second Mac format it and install the needed macOS this system was running. Then using this drive boot up under it to the run Disk Utility to repair the drive.
Depending on how you are running Windows you’ll need to do likely need to do the same with it.
Indice 0
Ajouter une réponse
NoOneUwU sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 41
