Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Acer Nitro 5 AN515-43 is a budget-friendly gaming laptop that was released in 2019. Typically features AMD Ryzen mobile processors paired with either NVIDIA GeForce GTX or AMD Radeon RX series graphics.
My acer nitro 5 dosen't turn
How can I fix it. Please help me
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
If your Acer Nitro 5 laptop is not turning on, it can be quite concerning. Here are some steps you can take to troubleshoot the issue:
  1. Check the Power: Make sure your laptop is properly connected to a power source and that the power adapter is functioning. Try using a different power outlet or a different power adapter if possible.
  2. Check the Battery: If your laptop has a removable battery, ensure that it's properly seated in its compartment. If it's a non-removable battery, skip this step.
  3. Perform a Hard Reset: Disconnect the power adapter and remove the laptop battery (if possible). Then, press and hold the power button for about 15-20 seconds. This will discharge any residual power from the laptop. Reconnect the battery and power adapter, then try turning it on.
  4. Check for Indicators: Look for any LED lights or indicators on your laptop. They might provide information about the power status or any potential issues.
  5. Try a Different Power Source: If you're using a power strip, surge protector, or extension cord, try plugging your laptop directly into a wall outlet to rule out any issues with the power source.
  6. External Display: If you have an external monitor, try connecting your laptop to it. Sometimes, the laptop screen might be the issue. If you get a display on the external monitor, it could indicate a problem with the laptop's screen or graphics.
  7. Disconnect External Devices: If you have any peripherals or external devices (USB drives, external hard drives, etc.) connected to your laptop, disconnect them and then try turning on the laptop. Sometimes, a faulty external device can prevent the laptop from booting.
  8. RAM Reseating: If you're comfortable opening up your laptop, try reseating the RAM modules. Sometimes, loose or improperly seated RAM can cause booting issues.
  9. Contact Acer Support: If none of the above steps work, it's recommended to contact Acer's customer support or visit an authorized service center. The issue might require professional diagnosis and repair.
  10. Warranty Consideration: If your laptop is still under warranty, reach out to Acer's support as soon as possible. Opening up the laptop or attempting repairs yourself might void the warranty.
Keep in mind that laptops are complex devices, and some troubleshooting steps might require technical expertise. If you're not comfortable performing certain actions, it's better to seek professional help to avoid further damage.
Indice 0
Title:
Acer laptop powers on but display is black (already tried basic troubleshooting)
Question:
Hello everyone,
I need some help with my Acer laptop. The laptop powers on normally (power LED is on and the fan is spinning), but the display stays black / no image appears.
Here are the troubleshooting steps I have already tried:
Checked the power adapter
Power cable is properly connected
Tried a different power outlet
Tried using another charger
Checked the battery
Charging LED turns on when plugged in
Removed the battery
Pressed and held the power button for about 30 seconds to discharge residual power
Reinstalled the battery and tried to power it on again
Checked the power source
Tested with a different power adapter
Tested with another electrical outlet
Unfortunately, the screen is still completely black.
My questions:
Could this be an issue with the LCD panel, display cable, RAM, or motherboard?
Are there any additional troubleshooting steps I can try before taking it to a service center?
Thank you in
advance for any help.
Indice 0
Ajouter une réponse
Sergej sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 43
Total : 579
