Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
Why does my keyboard from ifixit not fit?
I ordered a 2012-2015 MacBook Pro 15” keyboard from ifixit but it doesn’t fit my 2015 MacBook Pro 15”. There’s a notch below the spacebar on MacBook’s the upper case that doesn’t match up with the notch below the spacebar on the keyboard.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Good morning,
Last i checked, it isn't technically possible to replace the "keyboard" (the actual key mechanism) on it's own without pulling a Hugh Jeffreys. If your replacing the top case however, then that should work.
Can you add a photo showing the clearance issue as, from looking up on the internet, i can't find any obtrusive notch on the keyboard
Indice 0
1 commentaire:
My bad, I’ve realized that the keyboard does fit. I’ve uploaded a photo as an answer. I thought the bit that juts out (circled in blue) goes around the the bit that’s circled in red.
par
Ajouter une réponse
Owen Smith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 54
