fast charging doesn't work properly
Suddenly, when I plug in the charger on my phone, it keeps connecting and disconnecting all the time. But when I use another USB cable that doesn't support fast charging, it works fine but charges slowly. The problem occurs just with fast-charging cables; the adapter works perfectly on other devices, so I'm sure the problem is in the phone.
Ass you said it is connecting and disconnecting so the problem is your Cable
Maybe you will need to buy a cable that is fast charge se how many watts is your charger and get a cable that supports that wattage (a fast charge cable)and try to clean your port if its dirty. That might help too
par Ellusion
Thanks. I cleaned the charging port after I posted the question and now it owrks properly as it should. But thanks anyway.
par Roudi Alzkemi
Good My friend!!
par Ellusion
