The screen randomly Go's black but audio still plays.
It's model number is PN60F5300BFXZA.
IF I plug it in and out again it sometimes works for a bit but it will randomly go dark. I called a local repair shop and they said it's whole display should be replaced but I'm hoping it's just a conective issue.
I put a picture of the inside if that helps. I really don't want to pay 300 for repairs. And advice apreachiated
Indice
0
What is the video source? If you’re using a Roku/PlayStation/etc and it’s pumping out say 4k @ 60hz but your hdmi cable is only good for 4k @ 30 hz, this can cause the same issue as you’re describing. Go in your video source settings and manually decrease the video out and see if it stops.
par JnCA
@giantgarry try to post the image with your question again. This time follow this guide Ajout d'images à une question existante
What have you checked and what have you tried?
No picture with sound is commonly caused by a bad Y-sustain board.
par oldturkey03
@jnca there is a roku yes I will try that
par giant garry
@giantgarry look into https://www.hdmi.org/spec/index
par JnCA
