Automatic repairing loop going on but I don't unable to open laptop
Automatic repairing loop continues and then restart
Hi Rahul, Here are some possible fixes.
BIOS Settings
Power on and go into the BIOS Setup by pressing the F12 key then F10.
Go to General > Boot Sequence > Boot > Boot List Options
Change UEFI to Legacy or Legacy to UEFI and try to boot up to Windows. Usually it will be UEFI.
Windows Repair (Note: This can also be run from a bootable USB flash drive with the Windows installation on it)
Accessing Advanced Start-up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 will open into the Advanced Start-up environment
While in the Advanced start-up environment, use the following steps to use Start-up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
Other possible fixes From CMD Prompt
Run following:
SFC /scannow
Hardware
Run the Dell preboot diagnostic test (hardware) following these steps:
More details on running diagnostics
Watch out for any error codes that the diagnostic displays. The link above explains the error messages near the bottom of the page.
Let us know how it goes for further help.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 52
