Accessing Advanced Start-up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
- Turn on your PC.
- As soon as the Windows logo appears on your screen, press the power button to turn off computer.
- Repeat steps 1 or 2 two more times.
After the third interruption, Windows 10 / 11 will open into the Advanced Start-up environment
· While in the Advanced start-up environment, use the following steps to use Start-up Repair:
- Select Troubleshoot button.
- Select Advanced options button.
- Select the “Start-up Repair” button.
- Select your account.
- Type your account password.
- Click the Continue button.
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
Run following:
- Chkdsk /F
SFC /scannow
- Dism /Online /Cleanup-Image /RestoreHealth
(Note: Repair Windows 10 - "you need to sign in as an administrator to continue, but there aren't any administrator accounts on this PC"
- 1) Press Shift and Restart from the power icon (together)
- 2) Select Troubleshoot.
- 3) Go to Advanced Options.
- 4) Select Command Prompt.
- 5) Type "net user Administrator /active:yes")
Enable F8 key for booting into Safe Mode from CMD
bcdedit /set {default} bootmenupolicy legacy v
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
