Xiaomi Redmi 10 has a 6.5 in (165,1 mm) IPS LCD display with 1080p+ (2400x1080) resolution (395 ppi with 20:9 aspect ratio), 16M colors, 90 Hz refresh rate .
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
1 commentaire:
Hi Leo,
We're going to need more information; there are a lot of different ways a phone can be "not working" so you're going to have to be more specific about what your problem is.
What is the phone doing or not doing? When did it start? Did anything happen prior to the problem like getting wet, being dropped, software update, etc.?
The more information you can give us, the better chance you'll get an answer that helps fix your phone.
Hi Leo,
par Jerry Wheeler
