Aller au contenu principal
Pourquoi mon Lenovo Yoga 7 14ITL5 ne s'allume plus!?
j'appuie sur le bouton on/off ne s'allume pas
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
@steimaysn Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery (if this computer lets you do so) Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up.
Download the english Hardware Maintenance Manual for your Computer from here Page 42 in the manual tells you how to deal with the power module and the power cord. Since the manual is in english, you may want to try some of the free online PDF sites to get it translated into french if needed.
Translation
@steimaysn Commencez par les choses les plus simples. Coupez l'alimentation de l'ordinateur en débranchant le cordon d'alimentation de votre ordinateur. Déconnectez tous les périphériques externes de l'ordinateur. Retirez la batterie (si l'ordinateur le permet). Maintenez le bouton d'alimentation enfoncé pendant 30 secondes à 1 minute. Remettez l'adaptateur secteur en place et voyez si votre ordinateur montre un signe de vie.
Vous devez ensuite vérifier votre bloc d'alimentation. Assurez-vous que les tensions sont correctes. Vérifiez que les connecteurs ne sont pas pliés, etc. Ensuite, vérifiez le port de charge. Nettoyez-le de tout débris, etc. Utilisez quelques bouffées d'air pour le nettoyer. Vérifiez la prise DC-in de votre ordinateur portable. Assurez-vous qu'il n'y a pas de corrosion, de débris, etc. qui l'empêche de fonctionner. Si rien de tout cela ne fonctionne, prenez un ampèremètre et vérifiez si votre ordinateur portable consomme de l'ampérage à partir du chargeur. Ensuite, vous devez vérifier si votre carte mère est alimentée. Pour cela, vous devez bien sûr l'ouvrir.
Téléchargez le manuel d'entretien du matériel de votre ordinateur à partir d'ici La page 42 du manuel vous explique comment manipuler le module d'alimentation et le cordon d'alimentation. Comme le manuel est en anglais, vous pouvez essayer certains sites PDF gratuits en ligne pour le faire traduire en français si nécessaire.
Indice 0
Ajouter une réponse
Sté IMAYSN sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 27
Total : 320
