nintendo switch won't turn on
I put my console on charge overnight with the original charger, but in the morning I noticed that the console wasn't turning on, but I noticed that the screen was “on” but black. After that I managed to turn off the screen but I couldn't turn it on again. When opening the console, I tested some components and found two capacitors and one resistor shorted, as shown in the images. I removed all 3 and the capacitors did not present a short outside the board, but the resistor did. I removed 2 integrated components responsible for the load but the short did not disappear.
I will post the image indicating the components that are shorting out and if anyone can help me, I will be very grateful.
2 commentaires
The resistors could be 0ohm, which would explain the short (and not uncommon for development / debug purposes). With all of the components you mention removed, were you still observing a short when probing the board? There are a lot of possibilities here but I would be more suspicious of an active component (integrated circuit, FET, diode, etc...) failing than passives like resistors and capacitors. I'd also do as much visual inspection as possible, even if that meant taking the device further apart.
par Chris Green
@chrisgreen At first I found the problem. The problem apparently lies with the integrated P13USB which is located on the back of the board. I removed the integrated part from the board and the short disappeared, I have already ordered a new part and as soon as I change it I will post the new situation. Thank you so much for your answer!
par wagner.m.v
