Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Samsung galaxy A04s is an affordable smartphone with a large display and decent battery life. It offers basic features and functionality for everyday use.
Problème d'expédition je ne peux pas le charger
Un téléphone qui a un problème de charge ne peut pas être chargé
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@tajanimohammed If you have trouble with the charging then there are a few things you need to check. First you want to check your charger. Make sure it has the proper voltages. Next check your charging cable. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If all of that checks out okay, the issue can be related to your charging board as well as the flex cable from the charging board to the main board. Always check and change the battery as well.
If after all of that your phone still does not see the charger, the issue will be on the mainboard. For that you will need somebody with board level repair experience. Hopefully replacing the charging board, flex cable and battery will resolve this issue. Since iFixit does not yet have a guide for this, use something like this guide to work on your phone.
For the charging board, you are looking at something like this It is available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@tajanimohammed Si vous avez des problèmes de charge, il y a plusieurs choses à vérifier. Tout d'abord, vous devez vérifier votre chargeur. Assurez-vous qu'il a les tensions appropriées. Ensuite, vérifiez votre câble de charge. Vérifiez que les connecteurs ne sont pas pliés, etc. Ensuite, vérifiez le port de charge. Nettoyez-le de tout débris, etc. Utilisez quelques bouffées d'air pour le nettoyer. Si tout est en ordre, le problème peut être lié à la carte de charge ainsi qu'au câble flexible reliant la carte de charge à la carte principale. Vérifiez toujours la batterie et changez-la également.
Si, après tout cela, votre téléphone ne voit toujours pas le chargeur, le problème se situe au niveau de la carte mère. Pour cela, vous aurez besoin de quelqu'un qui a de l'expérience dans la réparation des cartes. Espérons que le remplacement de la carte de charge, du câble flexible et de la batterie résoudra le problème. Étant donné qu'iFixit n'a pas encore de guide pour cela, utilisez quelque chose comme ce guide pour travailler sur votre téléphone.
Pour la carte de chargement, vous avez besoin de quelque chose comme comme ceci. Elle est disponible dans de nombreux magasins en ligne.
Pendant que vous travaillez sur votre téléphone, prenez beaucoup de photos. Une fois que vous avez terminé, prenez ces photos et créez un guide pour iFixit. Cela aidera la prochaine personne qui aura le même problème que vous. C'est facile et amusant de créer ces guides. https://ifixit.com/Guide/new La communauté iFixit appréciera.
La réparation est la guerre contre l'entropie !
Indice 0
Ajouter une réponse
Tajani Mohammed sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 147
