Mon ordinateur ne s'allume pas
L'eau était tombée sur mon ordinateur, subitement le petit frère qui en avait n'a pas eu le temps de le sécher et il l'a directement allumé et jusqu'à ce jour ça ne s'allume pas
@katebacharles couple of things you always want to keep in mind. Never let water immersion dry on its own without cleaning it. Water is not an electrical conductor but the minerals in it are. So are the deposits left by it. Unless it is distilled or sterile water, it will contain Calcium, Potassium and other minerals that are conductive. Just letting it dry without cleaning it, will lead to corrosion damage as well as short circuits in a matter of time.
It has also been proven that Rice does not work. Rice is a great food but a poor tool. It has no place in electronics repair. Check this article for more information on that. Everything mentioned ion there applies to your laptop as well.
At least stat with this https://www.ifixit.com/News/41383/ask-if... to read about what you can do.
Here is what I always recommend and do for all water/liquid exposed devices.
The myth of rice as a tool for any kind of immersion accident has long been laid to rest as totally bogus. Rice does not work. It is the equivalent of doing absolutely nothing. For now, you want to stop trying to charge or otherwise use your laptop. This potentially can make a bad situation worse. This may further damage your laptop.
The next thing to do is to clean it. Disassemble your laptop. Since you did not tell us the exact model for your laptop, we can't help you with that. Remove the motherboard and every other board that is removable. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the boards, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone, all the points are still pertinent to your laptop as well. While you clean your boards, check for any obvious damage, like burned or missing components etc. Once everything is properly cleaned, I suggest to replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your laptop and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Let us know what model you Lenovo is so we can assist with the disassembly. Alway remember that you can add pictures of things that you may have questions about, with your original question
Translation
@katebacharles deux choses qu'il faut toujours garder à l'esprit. Ne laissez jamais une immersion dans l'eau sécher seule sans la nettoyer. L'eau n'est pas un conducteur électrique, mais les minéraux qu'elle contient le sont. Il en va de même pour les dépôts laissés par l'eau. À moins qu'il ne s'agisse d'eau distillée ou stérile, elle contiendra du calcium, du potassium et d'autres minéraux conducteurs. Le simple fait de la laisser sécher sans la nettoyer entraînera des dommages dus à la corrosion ainsi que des courts-circuits en peu de temps.
Il a également été prouvé que le riz ne fonctionne pas. Le riz est un excellent aliment mais un mauvais outil. Il n'a pas sa place dans les réparations électroniques. Consultez cet article pour plus d'informations à ce sujet.https://fr.ifixit.com/News/30047/rice-is... Tout ce qui y est mentionné s'applique également à votre ordinateur portable.
Consultez au moins ce site https://www.ifixit.com/News/41383/ask-if... pour savoir ce que vous pouvez faire.
Voici ce que je recommande et fais toujours pour tous les appareils exposés à l'eau/aux liquides.
Le mythe du riz en tant qu'outil pour tout type d'accident d'immersion est depuis longtemps considéré comme totalement faux. Le riz ne fonctionne pas. Il équivaut à ne rien faire du tout. Pour l'instant, vous devriez cesser d'essayer de charger ou d'utiliser votre ordinateur portable. Cela risque d'aggraver une situation déjà difficile. Cela pourrait endommager davantage votre ordinateur portable.
La prochaine chose à faire est de le nettoyer. Démontez votre ordinateur portable. Comme vous ne nous avez pas indiqué le modèle exact de votre ordinateur portable, nous ne pouvons pas vous aider. Retirez la carte mère et toutes les autres cartes amovibles. Vous devez retirer tous les écrans EMI. Si vous ne les retirez pas, autant ne rien faire. Après les avoir enlevés, nettoyez les cartes, les connecteurs et tout le reste avec de l'alcool isopropylique à 90 %. Suivez le ce guide, et même s'il a été écrit pour un iPhone d'Apple, tous les points sont également pertinents pour votre ordinateur portable. Pendant que vous nettoyez vos cartes, vérifiez qu'il n'y a pas de dommages évidents, comme des composants brûlés ou manquants, etc. Une fois que tout est correctement nettoyé, je vous suggère de remplacer la batterie. Toutes ces étapes ont pour but d'éviter une défaillance tardive causée par la corrosion. La meilleure chose à faire est de la nettoyer avec un nettoyeur à ultrasons, mais si vous n'avez pas accès à un tel appareil, ceci pourra au moins vous aider. Une fois que tout cela est fait, réassemblez votre ordinateur portable et réévaluez-le. Tant qu'il n'aura pas été nettoyé, tout ne sera que supposition. Malgré tout, les dommages causés par l'eau n'ont qu'une faible chance d'être entièrement réparés, mais vous pouvez au moins essayer.
Indiquez-nous le modèle de votre Lenovo afin que nous puissions vous aider à le démonter. N'oubliez jamais que vous pouvez ajouter des photos des objets sur lesquels vous avez des questions, avec votre question initiale.https://fr.ifixit.com/Tutoriel/Ajout+d'i...
Salut,
Désolé d'entendre ça. Il semble que l'eau ait pu causer des dommages à l'ordinateur lorsqu'il a été allumé sans avoir été correctement séché au préalable. Dans ce genre de situation, il est crucial d'éviter d'allumer l'appareil avant qu'il ne soit complètement sec, car cela peut entraîner des courts-circuits et d'autres problèmes électriques.
Pour résoudre ce problème, je te recommande d'éteindre immédiatement l'ordinateur s'il est encore allumé, de le débrancher et de le laisser sécher complètement pendant au moins 48 heures. On dit aussi que le riz peut aider à absorber l'humidité.
Si tu n'es pas à l'aise pour effectuer ces réparations toi-même, tu peux faire appel à un professionnel en réparation d'ordinateurs pour évaluer les dommages et effectuer les réparations nécessaires.
Bon courage, j'espère que tu pourras le remettre en marche bientôt !
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 38
