Aller au contenu principal
The Xiaomi Poco M3 is a budget smartphone which was released in November, 2020 and is equipped with a big 6000 mAh battery block, a tripple main camera and a 6.53 inch IPS LCD.
30 questions Voir tout
Mengapa wifi saya tidak bisa menjangkau lebih jauh
Jangkauan wifi tidak bisa jauh,hanya sampai jarak 4 meter kemudian wifinya terputus
Translation Indonesian - English
Title: Why can't my wifi reach further
Description The wifi range can't be far, only up to 4 meters then the wifi is cut off
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@febriml could be an antenna issue or could be an issue with your Wifi Module. Try to place your phone in recovery mode. For that follow the instructions from here See if a possible reboot of your software will change this.
If that does not work you could consider a factory reset. For that you must make sure that you have all of your files backed up and that you have the account information and password that you used when you first setup your phone. If you do not have this, you will get locked out. Use the factory reset option as a last resort only. Check something like this video to do a factory reset.
To disassemble your Poco use these guides Poco M3 as well as this video Check your antenna cables etc. Your sub_board is part of the antenna circuitry. Replace that and see if that changes anything. If it does not, then the issue will be related to your mainboard. For that you will need the schematic and the component layout diagram
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. It would be great to have one that shows how to replace the sub-board. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@febriml mungkin masalah antena atau masalah dengan Modul Wifi Anda. Cobalah untuk menempatkan ponsel Anda dalam mode pemulihan. Untuk itu ikuti instruksinya dari sini Lihat apakah kemungkinan reboot perangkat lunak Anda akan mengubah ini.
Jika tidak berhasil, Anda dapat mempertimbangkan untuk melakukan reset pabrik. Untuk itu Anda harus memastikan bahwa semua file Anda telah dicadangkan dan Anda memiliki informasi akun dan kata sandi yang Anda gunakan saat pertama kali mengatur telepon Anda. Jika Anda tidak memilikinya, Anda akan terkunci. Gunakan opsi reset pabrik sebagai upaya terakhir saja. Periksa sesuatu seperti video ini untuk melakukan reset pabrik.
Untuk membongkar Poco Anda, gunakan panduan berikut Poco M3 serta video ini Periksa kabel antena, dll. Sub_board Anda adalah bagian dari sirkuit antena. Ganti itu dan lihat apakah itu mengubah sesuatu. Jika tidak, maka masalahnya terkait dengan mainboard Anda. Untuk itu Anda memerlukan skema dan diagram tata letak komponen
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah Anda selesai melakukannya, ambil gambar itu dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki masalah yang sama seperti Anda. Sangat mudah dan menyenangkan untuk membuat panduan ini. Akan sangat bagus jika ada yang menunjukkan cara mengganti sub-papan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang Melawan Entropi!
Indice 0
Ajouter une réponse
febri ml sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 27
