Mower wont start due to oil runnig out @ last mow.
Before the last mow i changed the oil and filter and i didn't push in the drain plug all the way causing all the oil to drain out, then the mower died. There are no leaks and it will turn over but wont start. I was wondering where i should start first to troublesoot the problem.
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
justin, first off, all internal combustion engines have common things they need to function. Oxygen, fuel and a spark. Of course you are due for another oil and filter change. Close the drain plug. Check your spark. Check the timing, make sure your flywheel is properly aligned on the crankshaft. If you have spark, check for fuel. Check your carburetor, fuel lines and tank. Make sure they are all in working condition. Check your float and needle valve inside your carb fuel bowl. Make sure that you have plenty of air reaching your carburetor for a proper fuel/air mixture. Now you could get more specific answers if you can give us a motor model number and be more specific about what mower you have. As with anything, take your time and do one thing after the next. Do not get lost in the troubleshooting and start tearing things apart, be systematic. Hope this helps to get you started.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
justin sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 639
