Aller au contenu principal
Master multitasking with the Yoga Slim 7 Pro. This stylish 14″ ultra-slim laptop is packed with power, offering the lightning-fast performance of AMD Ryzen™ 5000 Series Mobile Processors, combined with stunning optional OLED 2.8K visuals, long-lasting battery life, and a range of smart features that will help you make the most of your day.
2 questions Voir tout
Replacing the USB Type-C cable on the charger
Hi, so an unfortunate thing happened. I stepped on the cable while the laptop was charging and the Type-C end got bent. You can get it to work, but it still is a bit annoying. Paying about 40-50€ for a completely new charger seems excessive, so I thought about just replacing the Type-C cable. The issue is, I can't find a cable that supports up to 95W charging for a laptop, so I don't know where to look for this specific part. I found a few on Aliexpress, but they we're all up to 65W. Any suggestions? Where could I get the cable or any other ideas?
Another option I thought about was buying this - https://www.aliexpress.com/item/10050047... and just replacing the Type-C end itself.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi @righn
If you're going to just replace the adapter's cable plug then it might be advisable to get a USB-C plug that has the correct current rating as well as not all plugs are the same it seems.
For example there are USB-C plugs capable of handling 65W as their current rating is ~3.0A whereas the 95W plug needs to have a current rating of ~5A. This is if both are supplying 20V that is.
Here are some examples of suppliers of a suitable plug type # UP31-CV-G-CM (specification sheet).
Depending on how many wires are in the adapter cable, here's an image showing the standard wiring colours used in USB-C.
Here's a link that shows the pinout for USB-C which may also help.
(click on image)
Indice 0
Ajouter une réponse
Tomasz Videos sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 29
Total : 76
