Aller au contenu principal
Pour réparer ensemble - Je crée un compte
3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
Ipad not recognize wired Headphone
My Ipad not recognize wired Headphone
I change usbc port but not fix it
Any idea please?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Which headphones are you using? Does it recognize other devices connected to the USB port (like an HDMI adapter, or USB drive)?
par
@flannelist My iPad recognize only charging
No headphones no usb drive
par
Ajouter un commentaire
1 Réponse
Solution retenue
It is worth making sure your iPad is fully up to date, or processing a full reset to see if that helps if you haven't done this already, but this sounds like a board level issue to me.
The iPad Pros are more similar to a MacBook in terms of their USB function they contain a proper USB controller, (that is also involved in charge function) that could have been damaged. They also contain a variant of the "Tristar" chip that is often damaged in iPhones or older iPads. In all possibility, one or both of these chips will need to be replaced to restore function.
Unfortunately it requires some advanced soldering skills to replace these, but it's a pretty common fault across the board. Image below is from the equivalent iPad Pro 11" but concept is the same.
Indice 1
Ajouter une réponse
M al sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 90
Total : 1,073
