Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Questions au sujet de 153 Voir tout
Power on self test Failed
G4 17 1ghz/1gb M8793LL/A-Powerbook5,1 - A1013 Power PC G4 3.3
In Diagnostics under Power On Self Test: I am getting
Last Run: today
Result : Failed
Failure Type: External Cache
What does this usually mean?
I do not really see a problem anywhere.
Hard drive problem? CPU? ...Something else?
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
You may notice some small degradation in speed. Sometimes a good internal cleaning will solve the problem. If all else is working OK, I really wouldn't worry to much about it.
Cette réponse est utile ?
Score 3
Commentaires:
Thank you.
I can probably learn how to do an internal cleaning here on Ifixit.
I also notice that my L3 Cache does not show up in the system profiler.
par
It used to show 1MB DDR L3...and now not.
par
Here's how to get to the heat sink, fans and rear vent to clean them out, you may want to reapply thermal paste at this time: PowerBook G4 Aluminum 17" 1-1.67 GHz Heat Sink & Fan Assembly Replacement
Here's the paste I use: Arctic Silver Thermal Paste Here's a generic guide on doing it: Comment appliquer de la pâte thermique
par
Could the need for a cleaning account for the "failed" test result and the disappearance of the L3 cache readout as stated above?
par
Ajoutez une réponse
Ernest Gagnon sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 632
