Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le HP EliteBook 840 G4 est un ordinateur portable élégant de 14 pouces conçu pour les professionnels. Il fonctionne avec des processeurs Intel Core de 7e génération, possède un châssis fin en aluminium et comprend des fonctionnalités de sécurité robustes pour un usage professionnel.
Why won't my laptop turn on after pressing the power button
After pressing the power button, it won't turn on and the charging indicator turns on when the laptop is plugged to a power source
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
When I on this laptop only power button light is blink
par
@rahulsaini8002 you will get more help if you post this as a separate question. Include your computers exact model number and what you have already tried and what you have already checked.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Here is one possible route to follow:
HP Laptop BIOS Recovery Win and B or V Key
  • Check Key Combination: First, make sure you are pressing the correct key combination. On some HP laptops, the key combination for BIOS recovery might be different. It's usually "Windows + B" or "Windows + V," but it could vary. Check your laptop's manual or HP's official support documentation for the correct key combination.
  • Power Cycle: Turn off your laptop completely and unplug it from any power source. Then, press and hold the key combination ("Windows + B" or "Windows + V") and while holding it down, press the power button. Keep holding the key combination until the laptop's screen lights up or you see any signs of BIOS recovery.
  • Use a USB Drive: If the key combination method isn't working, you might need to use a USB drive with a specific BIOS recovery file. Visit HP's official support website, enter your laptop's model number, and look for the BIOS recovery files and instructions for your specific model.
Another:
Shut down. Disconnect charger, open case and disconnect the battery. Press and hold power button for 30 seconds.
Now some just reconnect the battery and try the power button. I prefer to first plug in the charger to see if it works. If yes then you know the charger works and the battery may be defective causing a short. Then disconnect the charger and reconnect the battery. If it works the BIOS was probably corrupted somewhere. If not replace your battery.
Indice 1
Ajouter une réponse
Anthony Kariuki sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 68
Total : 1,156
