Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Rpm is not istable.it is up and down specialy if the ac is working
Why my accent 2015 model is the RPM unstable. Up and down.specialy if ny ac is working?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
4 commentaires
My RPM is too high and the care consumes alot of fuel
par
@fatihkasozi Faith, you'll have much better luck starting your own question. Assuming you also have a Hyundai Accent SE, please include the year, transmission and engine information and what you've done so far to try and figure out the problem.
https://www.ifixit.com/Answers/Ask/Hyund...
par
It's a Hyundai Accent 2012 model engine capacity is 1.6 I have tried changing the coils but it's not working the RPM is too high when ever I start the car and sometimes even when IAM driving and it dose this even when the AC is off
par
Same issue I had
par
Ajouter un commentaire
2 Réponses
Solution retenue
The rpms will fluctuate especially with the A/C is on because the compressor kicks in and out which throws extra load on the engine and the frees up the load when it kicks out. The coolant radiator fans can also cause this by putting extra load on your alternator, all this being said the fluctuation should be minimal!
Indice 3
1 commentaire:
I would like to point out that although this is good information, it doesn't actually cover the original question fully, as the poster specifically said the RPMs are unstable with the A/C off, but is worse with A/C on. The answer here doesn't account for what's going on when the air conditioning is not on.
par
So what is the posible damage.
Indice 0
Ajouter une réponse
Khalid sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 35
Total : 555
