Why wont my iPod touch turn on.
My Ipod switches between the low power/ charging icon and the apple symbol, but never seems to charge.
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Brad, there are a few things you could try. Make sure that you have a good USB cable, check your dock connector for any debris, corrosion or bend/broken pins. Try a AC charger to charge your iPod. If that should not work I would try to replace the battery. Here is the guide for it and the battery is available right here. Be careful with the soldering so that you do not destroy the solder pads. Hope this helps, good luck.
Image iPod touch (Gen 2) Replacement Battery
Produit
$14,99
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Brad sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 803
