Aller au contenu principal
4ème génération de l'Apple iPhone. La réparation est relativement simple, mais la vitre avant et le LCD doivent être remplacés ensemble. GSM / capacité de 8, 16 ou 32 Go / Modèle A1332 / noir et blanc.
2375 questions Voir tout
Question close
Phone will not power on or be recognized on computer. Fix?
So I have an iPhone 4 that will not power on or be recognized in a computer. I removed the battery and plugged the phone up, but no response. I ordered and replaced the dock connector. but still didn't get a response. Does it have a bad logic board or is there something else that I can try?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Replace the battery. If that does not help, it's probably the logic boarfd.
Indice 0
Hi Curtis
Have a read of this post
Will not power on, what could it be?
This post I believe gives you good recommendations to start of. Also have a look at the logic board and see if you can notice any corrosion, if so do a isopropyl alcohol solution bath to help loosen the corrosion and using a soft bristle brush like a soft toothbrush lightly brush the corrosion off. The alcohol bath will also help remove any kind of moisture that may be on the logice board.
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 505
