backlight not work but iPhone still works
would this be the problem Proximity Sensor Ribbon if the backlight not working
Most likely the backlight coil has gone. See the pic for the location.
It's quite a tricky repair so you may want to find a company to do it for you.
thank you for the help and how do you take off the sliver panel too get too it
steven, sorry to butt in. If you are referring to the EMI shield, you do not have to take that off. The coil is on the left side as shown in red on the image. There is a way to check your coil first. Take a look at this video. If you are not sure if you want to do the coil repair, here is a video that shows the complete repair. Good luck.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 378
2 commentaires
right done the 6r8 coil been replace but still don,t work
par steven
before you changed the coil, did you check your LCD display on another phone? My first suggested would have been to change the LCD display, then the coil then the backlight IC.....
par oldturkey03
