Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Flagship smartphone from Huawei released April 2019. Featuring a 6.47" FHD+ OLED screen, in-display fingerprint sensor, 40 MP main camera plus 8 MP telephoto camera and a new earpiece speaker technology. Model VOG-L29 and VOG-L09.
How to fix headphones with split-jack 3.5
Soo my jack in my headphones stopped working, so I cut the insulation off and looked at the wires. My headphones have 1 cabel, that splits into 2 (mic and sound jack) and then you can add a reduction so it connects once again into one.
I am sure the problem is in the 2-jack section, because before it stopped working it sometimes got really quiet so I could barely hear anything, and I could fix that by rotating the sound jack so it can get better connection.
Update (07/16/24)
soo idk if the images are here somewhere, I'll just send a link now https://imgur.com/a/qmcJq7M
idk what should I connect to what because of the wire numbers being off @amber
Update (07/23/24)
@abhimannuec should I connect it like this?
https://imgur.com/a/glKgyJS
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
@abhimannuec Sorry, I think the images that should work here didn't, so here I send the link. I think you'll see where the problem is, can you please tell me what should I connect to what?
Also my dad has one of these classical meters where you can select from like 15 different option with a turning wheel
par
@jankocvara it's actually fairly easy to add images Ajout d'images à une question existante
Now, let's try and figure out what you are trying to build here :-)
par
Ajouter un commentaire
2 Réponses
Problem with headphone pin, some time internal connection or wire separated, please check with other headphone
Update (07/16/24)
Please reconnect according to colour using soldering, do u want connect to splitting type jack pin
Update (07/16/24)
Do u have multimeter or any kind of continuity tester
Indice 0
1 commentaire:
par
@jankocvara is the third picture the original headphone jack? I that the one you want to connect? First you have to identify which wires the for the Left and the Right speaker and then the one for a mic. After that you connect it standard for a TRRS connector.
Tip is commonly Left speaker
Ring is Right speaker
Ring is ground
Sleeve is Mic in
To test your headphone jack for the corresponding wires, Use a multimeter and set it to ohm mode. If it has continuity mode, set it to that. Strip the insulation about a 1/4 of an inch (6mm) of each wire. Place one probe on the tip of the connector. With the other probe check each one of the wires. The one that shows continuity will be the Left speaker. Now do the rest of the wires as well. Just move the probe on the jack to the 1st Ring, test the wires....and so on. Write those colors down so you know which wire belongs where.
Indice 0
1 commentaire:
@jankocvara for the headphone it will be a bit trickier. Do you know how to remove the ear cushions and to get to the wiring of the speakers?
par
Ajouter une réponse
Jan Kočvara sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 209
