My phone is off and doesn't turn on
What is wrong with it?
@sajad712 since we do not have all the details from you, start off with the basics and work your way to the more complicated.
first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery. To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. If not, then the issue is either the charging port or the charging circuit.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 43
1 commentaire
@sajad712 what have you checked and what have you tried to fix this? did anything happen to your phone? We will need more details in order to help you.
par oldturkey03
