Aller au contenu principal
Removing scratches from the back?
I got a iPod nano for 10$ and it does work, but it is scratched up like mad on the back
Is there anything i can try to to remove some, if not all of the scratches?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Nick, what I do with the older back plates is to use some buffing compound and a buffing wheel. This usually removes most scratches Depending on how deep they are). Your Nano is a bit small and tough to hang on to, so be careful if you use a wheel. Otherwise you will have to buff it by hand. Hope this helps, good luck.
Indice 2
5 commentaires:
Most of them are the light ones that are pretty typical on shiny back iPods, a few lighrt scratches
par
Yes, they should buff out.
par
i'll have to try it and get a case to avoid this again, although it's commonplace, i do want to keep it minimal
par
Thanks for accepting my answer. Yes, a case would be good, since they do get banged up quite a bit. Good Luck.
par
this one has dings on the faceplate from being dropped, and scratches too, pretty clear old owner, who was a friend never used a case
par
Ajouter une réponse
Nick sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,481
