Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Imprimante 3D résine LCD mono 4K. Sortie en 2021. Ne pas confondre avec la Mars 3 Pro similaire sortie en 2022.
Why does my printer shut down when I insert the usb drive in?
Hi I’m encountering an issue with my printer completely shutting off when the usb drive is inserted into the drive portion of the printer. What can this be? The printer turns on perfectly no issues whatsoever the touch screen works just fine, problem is the usb port I haven’t tried to fix or adjust anything yet. Please help! Thanks!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
  1. If you have inserted the USB flash drive into the easy-access USB port, remove it.
  2. Make sure that paper is loaded in the tray.
  3. Check the printer control panel for messages. If paper is jammed in the printer, clear the jam.
  4. Close any control panel menus that are open.
For more checkout the following thread: https://support.hp.com/us-en/document/is...
Indice 0
1 commentaire:
This is for my Elegoo Mars P 3D resin printer the issue is with the usb port on front of the 3D printer my apologies for not clarifying this
par
Ajouter une réponse
Stacey Marie Sanchez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 38
Total : 348
