Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Powers on as normal but with no sound.
Everything works - the touch screen, bluetooth, etc. Except there is no sound - no audio, no beeps no music.
I've tried reseting via screen options and the small paper clip method.
I've also tested my car speakers by installing a different car stereo and the speakers work fine.
Any clues?
Could it be a blown amp in the unit?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
Mine shows AUD DISCONCT. It’ll
Work fine for a while then lose all sound. It’s running through a Bose speaker amp and speakers in nissan 350z. I thought that maybe the amp might be overheating from receiving an amplified signal but the problem is so random I dont think that’s it.
par Partager
Ajouter un commentaire
2 Réponses
First, check for simple issues such as mute accidentally turned on. Some Kenwood models have a preamp-only mode that turns off the internal amplifiers. It's buried deep in the menu options. Check for that and disable if necessary. Also disable any demo (demonstration) mode in the menu since that can also affect the amp's output. It's possible the head unit's amp is bad, but that's unlikely and especially unlikely to affect all channels at once. It's more likely a menu setting or a wiring/connection problem.
Indice 0
Following.. Mine was working just fine for a couple of years with no issues and suddenly happened the same, everything works just fine except there is no sound and no beeps either. I have no external amp. I use the head unit for the 4 speakers and the subwoofer output for a 12" Amplified Subwoofer, which didn't sound either except the "buzz" sound when I plug or unplug the subwoofer.
Indice 0
Ajouter une réponse
Nish sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 76
30 derniers jours : 309
Total : 5,958
