Which Adhesive Strip is used for the Series 4 Watch?
There's two gaps in the watch that need to be sealed: between force touch sensor and LCD, and between force tough sensor and chassis.
Remplacement de la batterie de l'Apple Watch Series 4
Step 6 of the repair guide stated that, the force tough sensor should be separated from the display, and it took me 10 minutes to clean up the adhesive.
Then I noticed that in the repair guide, only ONE installation of adhesive strip is mentioned. I used two adhesive strips provided in the IFIXIT repair kit, heated up the display, and provided high and even pressure between the LCD and the chassis. Didn't work. 2 days later, the LCD fell off, and both adhesive strips didn't stick at all
It is possible that the watch still functions. I need to know what adhesive I should use, and how I can make them stick correctly. NOTE: Please specify which adhesive to use between each gap
