Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le HP EliteBook 840 G4 est un ordinateur portable élégant de 14 pouces conçu pour les professionnels. Il fonctionne avec des processeurs Intel Core de 7e génération, possède un châssis fin en aluminium et comprend des fonctionnalités de sécurité robustes pour un usage professionnel.
My battery died fast
my laptop battery died fast and its just charge for 80% and its died also when it close
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Hi,
Your laptop has been around since 2008 and I would suggest it has already had a battery replacement at some time in the past.
Depending on when it was last replaced, it’s more than likely the current battery is no longer capable of taking full charge or holding charge any longer.
If you have more recently replaced the battery it’s possible that it wasn’t a good quality battery or has developed an internal issue that affected its ability to perform as it should.
The other thing you may need to check is the charging power supply, as it may no longer provide enough charge voltage or current due to fatigue or cable damage.
You could try another charging plug pack & cable if you have access to one.
You may need to either have the charge pack & cable & battery tested at a repair shop.
Or if you know the battery hasn’t been replaced for a long time and your charging pack is functioning properly, buy a replacement battery.
Hope this helps
Indice 0
Ajouter une réponse
Mohammad Khair Al-Sairafi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 207
