Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Galaxy A3 (2017) est un smartphone milieu de gamme de la série des Galaxy A. Il a été présenté par Samsung en février 2017 en même temps que les Samsung Galaxy A5 (2017) et A7 (2017).
Comment reparer ou changer accelerometre/compteur de pas
Bonjour, le comptage des pas ne fonctionne plus. Je pense que c est l accelerometre qui est soit deconnecté (j ai fait changer la batterie, et le podometre fonctionnait avant ce changement), soit defectueux.
Ou se trouve t il dans le telephone svp ? Comment le changer ?
Merci
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
@agnesmadeleine the accelerometer is an IC soldered to the circuit board. Check this image
U7007 is the part you are referring to.
Try the usual steps first. Check your phone setup and make sure that you have updated all your software. Next you want to go ahead and try your proximity sensor in Safe mode. You get your phone in safe mode by:
Press and hold the. Power button. and. Volume down button. Touch and hold. Power off. until the 'Safe mode' prompt appears then release.
To confirm, tap. Safe mode. . ...
Once it is in Safe mode you want to make sure that Airplane Mode is turned off. Now try your sensor. If it works in Safe mode, then the issue is actually a bad 3rd party App you downloaded. You must uninstall those until you find the one that may have caused this.
If your sensor does not work in Safe mode either, try to see if you can get into the hardware testing mode by dialing *#0*# to get to the Samsung Hardware Diagnostic Test Menu. Here you can use the menu for the sensor test and see if it passes.
Now, you can check some of the hardware around the sensor. Follow the Samsung flowchart for this
Now use this Component Layout and with the search function of your PDF reader, find the components to be checked according to the flowchart (i.e. U6009) on your circuit board.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@agnesmadeleine l'accéléromètre est un circuit intégré soudé au circuit imprimé. Vérifie cette image
U7007 est la pièce à laquelle tu fais référence.
Essaie d'abord les étapes habituelles. Vérifie la configuration de ton téléphone et assure-toi que tu as mis à jour tous tes logiciels. Ensuite, tu dois essayer le capteur de proximité en mode sans échec. Tu peux mettre ton téléphone en mode sans échec en :
Appuie et maintiens enfoncées les touches . Bouton d'alimentation. et. Bouton de réduction du volume. Touche et maintiens. Éteindre. jusqu'à ce que l'invite « Mode sans échec » apparaisse, puis relâche.
Pour confirmer, touche. Mode sans échec. . ...
Une fois qu'il est en mode sans échec, tu dois t'assurer que le mode avion est désactivé. Essaie maintenant ton capteur. S'il fonctionne en mode sans échec, le problème vient en fait d'une mauvaise application tierce que tu as téléchargée. Tu dois les désinstaller jusqu'à ce que tu trouves celle qui est à l'origine du problème.
Si ton capteur ne fonctionne pas non plus en mode sans échec, essaie d'entrer dans le mode de test du matériel en composant *#0*# pour accéder au menu de test de diagnostic du matériel Samsung. Ici, tu peux utiliser le menu pour le test du capteur et voir s'il réussit.
Tu peux maintenant vérifier le matériel autour du capteur. Suis l'organigramme de Samsung pour cela
Utilise maintenant ce Component Layout et avec la fonction de recherche de ton lecteur PDF, trouve les composants à vérifier selon l'organigramme (c'est-à-dire U6009) sur ton circuit imprimé.
Pendant que tu travailles sur ton téléphone, prends beaucoup de photos. Une fois que tu as terminé, prends ces photos et crée un guide pour iFixit. Cela aidera la prochaine personne qui aura un appareil avec les mêmes problèmes que toi. C'est facile et amusant de créer ces guides. https://ifixit.com/Guide/new La communauté iFixit appréciera.
La réparation est la guerre contre l'entropie !
Indice 0
Ajouter une réponse
Agnes Madeleine sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 9
Total : 259
