Can I transfer songs from my iPod Nano to an iPod Touch?
I was given an iPod touch and was wanting to transfer all my music from my older iPod Nano 3rd Generation to the iPod Touch. Is this possible?
another way is to manually copy the hidden music files on your iPod nano to your computer, then transfer from there to your iPod touch using iTunes. Here's how:
First enable Disk Mode on your iPod nano, then connect to your computer and it will mount on your desktop.
next, follow these instructions (for Mac or PC) to show hidden files on your Mac or PC. You will then be able to navigate to and see the hidden directory on the mounted iPod volume
For example on a Mac, the iPod's music files will now be visible in subdirectories of the mounted volume in:
/Volumes/[YouriPodName]/iPod_Control/Music
now copy the entire contents of the iPod_Control/Music folder to your hard disk, and then later drag the resulting copy to iTunes and then sync your iPod touch
very good bac, I didn't know this +vote
That's generally my favorite way
You can try Syncios. Syncios is a free yet powerful iPod to PC transfer software which can help to transfer App, Music, Photo, Video and Ebook from PC to iPod/iPhone/PC without using iTunes as well as transfer from iPod to PC, iPhone PC and iPad to PC. You can download it freely from http://goo.gl/7GkJlW
Does this work, tho, for music that was burned from CDs?
Hey is there a way to transfer my songs from my iPod nano to my new iPod touch with my cell phone without a laptop please let me now ?
The only way I am aware of is to use a program like Senuti to pull the songs from your Nano onto iTunes. Then unplug the Nano, plug in the Touch, and drag the songs from iTunes onto the Touch.
Good luck!
iPodrip will also do the job and will work with both Mac & PC. Senuti is Mac only. http://thelittleappfactory.com/irip/?gcl...
If you're asking if you can go directly iPod to iPod, then the answer is no.
But otherwise, just see the other answers about getting music from your iPod to your computer. I also use iPod->Folder and iPodDisk (both for mac though).
Besides all the ripping suggestions people have- how did you get the music currently on your nano? If it's still in iTunes and you sync it regularly, just sync the same iTunes library with all your music to the Touch.
Unfortunately, although the Nano can show as a "drive" on My Computer, the Touch doesn't.
The copying the hidden folder option is the best way around this, as it is a very good way of copying your ipod's contents to a different computer without using itunes.
The only problem is that the original mp3 names will be renamed to four figure codes - fhgd, vbgh etc.
To find out which file is which, set the the folder they are in to display 'details' and you will see their titles. you will probably find that importing them into itunes for the Touch will display the names, but you may find some that do not appear properly and will need editing via getinfo.
The title of this thread is about transferring from a Nano to a Touch. Recent posts are completely off topic and about phones. The point is that on XP and some other platforms the ipod shows as a camera when connected and cannot be accessed. That is why the relevant answers were made. Using iTunes to transfer files will not work for the situation the initial poster experienced.
REcent answers are, again, totally unrelated to the original question. My anser and the preferred answer are the only way to deal with the original problem.
To transfer songs from iPod Nano to iPod Touch
1 Attach an iPod USB computer cable to the iPod Nano. Connect that iPod Nano to the computer.
2 Open iTunes if it doesn't automatically open. If you don't have iTunes, you can download it for free on the Apple website. The iPod Nano should be listed under "Devices" on the left panel of the iTunes screen.
3 Connect the iPod Touch to the computer using the iPod Touch USB computer cable. It will also appear under "Devices" in iTunes.
4 Select everything except music files on the iPod Nano to copy and paste to the iPod Touch. Once everything has been completely transferred, there will be a pop-up message to let you know it is complete.
5 Open "My Computer" on a PC or "Finder" on a Mac and select the iPod Nano. Copy the iTunes Music folder. Then select the iPod Touch and paste the copied folder in its iTunes music folder. Wait for the completion message before disconnecting.
Totally irrelevant and wrong answer for the original problem
Aplogies - added to wrong post
Yes, you can do it out for yourself now by my recommend way.Some times iTunes may fails to sync your Apple device while trying to transfer your files. At such situation you need an advanced iPod to iPhone transfer application by which you can easily transfer your files. This application easily sync your device and allow you transfer, modify, delete, manage files. Just follow these simple steps to transfer files from one multimedia device to another: Don’t Miss: How to Transfer Music from iPhone to iTunes
Connect your iPod or iPhone to your computer.
Sync the device for trasnfering data.
Use an application to easily transfer files.
Drag and drop files iPod to iPhone or vice versa.
For more information about how to transfer files to Apple's devices through the MacBook or PC you can visit: How to Transfer Songs from iPhone to Mac Computer.
If you are looking to transfer iPhone files then it is informed that it is possible to transfer files . iTunes is an application with which it is easy to transfer files but this take large and enough time. iPhone transfer for Mac has made easy and possible to transfer files.
Yes. The transfer issue become easier than before, because there are a lot of file transfer tool now other than iTunes that can do the job conveniently. Among all, I l like the iPubsoft iPad iPhone iPod to Computer Transfer most, because it allows to sync the songs or other files between two different iDevce at the same time with 1 click.
You can transfer your data from one iPod to another iPod.
Step 1: Connect Two of Your Devices to Computer
To start with, connect two devices (they can be Android, Symbian or iOS devices) to your computer via USB cables. Run Phone to Phone Transfer. When your devices are connected and detected by MobileTrans, you'll get a window as follow.
Step 2: Start to Transfer Data from One Phone to Another
Now, data on your source phone that can be transferred are listed in the middle, such as contacts, photos, messages, etc. You only need to mark those you're going to move to another phone and click “Start Copy”. Then they can be fully copied to your destination phone.
If you need to empty your destination phone before the transfer, tick off the ”Clear data before copy” bar under the destination phone picture.
Be sure neither of your phones disconnects during the whole progress. When transfer progress is completed, please hit the "OK" button.
Yes. You can simply transfer music between 2 iPods.
Here's a guide for your reference. Transfer music from iPod to iPod
You can use iCloud Backup to back up your previous device and then restore the backup to a new device. Your saved messages, email accounts, photos, notes, and other personal settings will be transferred to your new device.
1. Go to Settings > iCloud > Storage & Backup.
2. Turn on iCloud Backup.
3. Tap Back Up Now.
4. Wait until the backup finishes. How long it will take depends on how big the backup is and how fast your Internet connection is.
5. Choose Restore from iCloud Backup from the new one.
6. Enter your Apple ID and password.
7. Choose the backup of your old device and tap Restore. Wait until the device finishes restoring from the backup.
You can also follow this guide: How to Transfer Music from iPod to iPod touch
here this is my site i have write new Content for how to android file transfer between mac , PC ,Linux and Android by wifi , all type you need it with all OS , Try this and give me your opinion by command in my site , my article will probably help you http://sifiwiki.com/android-file-transfe...
It is a wise choice to backup all the data in your iOS devices to computer because you just never know when the data loss issue would happen. This 3 in 1 functional transfer tool is right here providing you with quick and safe way to copy content like videos, photos, music, eBooks and more from all iPad, iPhone and iPod models to computer or transfer between ios devices.
Of course. You can do it via iTunes, but this might be a bit troublesome. Or you can use a tool which i personally think is alright. iPhone manager. One thing about it is that it needs to be paid... though it can really help on managing files on iOS devices or between them. Check this out to see if it's ok for u. Transfer Music from iTunes to iPhone
Here is how to transfer videos from iPhone to computer & transfer songs from iPod to iPod:
Install the latest version of iTunes on your computer.
Connect your phone to your computer
Click on its name in iTunes
On the Summary screen that appears, UNcheck the box that says "Manually manage music and videos"
Click the Music tab at the top of the iTunes screen
Check the music you want on the phone
Click Sync
Sometimes, you lost your iTunes library, or your computer crashed and you have to format your computer, but the songs and movies are still on your iPod, you may want to transfer them from iPod back to computer. Or you may get a new computer; you want to copy the music and video from iPod to the new computer iTunes library. And this step by step guide will help you do that. The tool you need is .iPod to computer transfer
Of course it is possible!
It is quite simple for you to transfer your iPod songs to another iPod easily.
I've have the same problem as you, and my friend who works in Transphone recommend their software iOS Transfer to me.
I think the best way is to use some professional third-party software. So you don’t need to be bothered by the complex steps, the safety issue and time cost. Try this iPhone transfer.
It seems that iTunes is not a perfect software in this aspect and that's why I write this article. I would like to recommend an iTunes alternative – FonePaw iOS Transfer to help you transfer music from iPod to iPod without any difficulties.
FonePaw iOS Transfer allows you to copy music from iPod to iPod directly. It won't erase any data on both the iPods. What's the great is that this software supports transferring all of your songs, including those not got from your iTunes.
Answer: How to transfer music from iPod to iPod directly ? In this case, a third-part software Coolmuster iPod to PC makes this come true. Coolmuster iPod to PC allows you to directly transfer songs from iPod to iPod . It also allows you to transfer music from iPod to iTunes or computer. And you can also transfer photos, videos, playlist, audiobooks and more from iPod to iPod directly.
To new readers - there is no need to buy ANY software to xfer songs from a Nano to a Touch. When you plug in a Touch it comes up as a camera on Windows, but when you plug in a Nano it comes up as a drive.
Turn on "see hidden files" on the drive folder that opens up, and you will see a hidden folder which contains several folders including one that holds all the mp3s stored on the ipod, each divided into sections.
Each batch of your mp3 files is in a folder named F00, F01 or some similar three letter ID. Each mp3 is also named with a four letter code. Just copy the files to a folder on your PC and either go through them to name them individually or more easy, download a mp3 identifying app which will rename each file correctly. *mp3tag trial version et
You may find that itunes will rename them as you put them onto the Touch.
This is also a good way to keep a hard copy of all your mp3s in case of "disaster"!
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 39,559
9 commentaires
I had my older iPod at college and used friends computers to download music. I don't have access to those computers or music libraries anymore.
par DonnaL
Have any of you tried "Pod to Mac" free download?
par DonnaL
Have you got a link for it?
par mayer
I haven't tried it, but here's the link. it's free to try or $19.95 to buy:
http://www.podtomac.com/
par iTronics Repair
Yes I have a link:
http://download.cnet.com/Pod-to-Mac/3000...
Thanks for all your help! Will let you know if it works.
par DonnaL
Voir 4 commentaires en plus
