Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels et instructions de réparation pour le Macbook Pro 13" avec puce Apple de 2e génération (M2) et écran Retina de 13,3 pouces. Modèle A2338. Première sortie le 15 juillet 2022 à la WWDC 2022 aux côtés du Macbook Air M2.
BMU battery data cable connector broken
Hi there! I opened my laptop after I spilled a tiny amount of liquid in it… all good until I put everything back. Right at the end, by mistake, I pulled the cable from the BMU unit. One of the pins in the connector fell off. What are my options now? Please help …
Thank you…
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Is this just the cable that has broken? If so you can find them on numerous sites for example on iFixit. If it is the actual connector on the logic board then you'll have to source a new connector from somewhere or someone who has a donor unit, and then find a specialist to remove / solder on the replacement..... This may prove to be a little hard to find.....Good luck!
Image Replace the small flex cable that connects the battery daughter board to the logic board.
Produit
MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
$16.99
Indice 0
2 commentaires:
It’s the connector on the BMU. Thank you
par
Yes the top part of the logic board connector (battery side) got pulled off. If you still have the piece you might be able to glue it back. But you will need to be very precise with the glue’s placement as it mustn’t interfere with the contacts or the latch. Replacing the connector is possible but it will take a hot air rework station and some skills to do it without making a bigger mess. Or, you just bite the bullet and replace the battery as the connector is on the battery side.
Either way I would remove the battery following this guide Changement batterie Macbook Pro 13" 2022 (M2) as the person with the needed tool and skills only needs the battery and the needed connector BMU Cable Connector it’s also available from other sources. Or just replace the battery the guide offers the part info.
A better view on the connector
Indice 0
3 commentaires:
@danj I think you have confused yourself? The part you say is broken is on the logic board, you then say to replace the battery? This all makes no sense to me.....
par
@livfe - yes it’s on a circuit board which is part of the battery. I’ve added a better image to my answer so you can see.
par
@danj Ahhh OK better now, cheaper & easier solution!
par
Ajouter une réponse
Alexandru Gorgos sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 29
Total : 1,054
