Maytag MDB8859AWB2 Unit stopped and no power present (keypad, etc.)
Hello, was unsure to begin a new discussion or ask question here. Issue is with Maytag MDB8859AWB2 dishwasher. Has always worked without issue until recently. Unit stopped and no power present (keypad, etc.). Noticed water at bottom of tub as if cycle was interrupted, Checked circuit breaker and wasn't tripped. After further research, believed issue to be BiMetal Thermal Cutoff Fuse part W10258275. Videos shown here:
https://www.youtube.com/watch?v=Eyeojisn...
https://www.youtube.com/watch?v=T0u930Nq...
Turned off power / breaker to the dishwasher and replaced the thermal fuse. Unit again worked! Approximately two week later, dishwasher again stopped working / no power and water at bottom of tub. Breaker was not tripped. Again replaced the BiMetal Thermal Fuse, and dishwasher once again began working. After about another two weeks of operating without issue, it again stopped. My question is this, what would cause unit to lose power and cause thermal fuse to again become defective?
Would the following cause the dishwasher to lose power / damage the thermal fuse (did not test fuse with multimeter etc. after replacing); Heating Element failing, defective High Limit Thermostat, defective Control Board, defective Control Panel, issue with Water Valve, Drain Pump, Circulation Pump shorting, clogged drain hose etc.?
Update (11/12/24)
Thank you jayelf! Overlooked the notes at bottom left of page 1;
