Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Neuvième génération d'iPad, sortie le 24 septembre 2021, disponible en modèles 64 ou 256 Go. Numéro de modèle A2602.
iPad won't charge or turn on after battery change
I replaced the battery in an iPad 9 and now it will not take a charge. Everything was functioning fine after with the new battery. Then a short time later it will no longer charge. When I connect a USB power meter it shows 0.01 amps. Nothing changes with a different charger and cable. Is this a board level problem?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
One of the most common issues with iPad repair is that the battery connectors on these are really easy to damage because all the pins are on the underside of the connector. And so they are often bent went trying to isolate them from making contact with the board.
The thinner pins on the far ends of the connector are used for battery data—that means your board may not be getting some sort of data it needs about the battery. So it may not be charging because it doesn't even think a battery is connected. Or that it thinks the battery is full, or it's just confused. Could be any of the above, but it's the first thing I would check in this case.
Indice 2
Ajouter une réponse
Julian sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 46
Total : 209
