Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'iPod de septième génération, commercialisé et vendu sous le nom d'« iPod Classic », est sorti en septembre 2009 et ne présentait aucune différence visible par rapport à la version précédente. Il a simplement remplacé l'iPod Classic 6.5 de 120 Go par une version fine de 160 Go.
Why is my iPod Classic making a clicking noise?
My Ipod Classic has started making a clicking noise and just tells me to take it to the apple store to fix. Just wondering what actually could be wrong. It still charges fine, so I was thinking it might be the spin disk or a chip but not really 100% sure. Has anyone else had this issue and know what needs to be repaired?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
@shapop62714 without actually hearing/seeing it and only going by your description, this sounds like a bad HDD. Pretty common for the year and model. At this point I would replace the HDD.
You replace it tthe same way as you would on the 6th gen Remplacement du disque dur d'un iPod classic
Yes, you will get a few answers that will suggest you convert your iPod to a SD card etc. but I just prefer to stay original. That way I do not run into compatibility issues. No, I do not need a device that will hold 15,000 songs :-)
Indice 2
3 commentaires:
I thought it might be a HDD problem, interesting to know it was a common problem but only happened to me so late in the game. Truthfully I'm with you, I don't really need that many songs, I barely filled 160GB.
par Partager
@shapop62714 what happens with these HDD is that they really "gum up" and the read/write head arm starts to not properly move. It is actually more an issue of underusing the iPod that can cause this :-) Like I said, I'd pop a new HDD in there and continue to use it. The Classic iPod 's are still my favored music player :-)
par Partager
Awesome, thanks for the explanation :)
par Partager
Ajouter une réponse
Sha Pop sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 43
30 derniers jours : 146
Total : 2,423
