Can't see wifi Connection. what would I do
Can't see wifi Connection. what would i do
Hi @arjie
Try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it detects and connects to the network and if the connection remains stable.
If it does, there may be an antenna problem in the phone e.g. loose or faulty.
Here's an image taken from this teardown video showing the antenna connections.
(click on image)
If your phone can't see a Wi-Fi connection, the first steps are to check if your phone's Wi-Fi is turned on, ensure you're not in airplane mode, and then try restarting your phone and router; if that doesn't work, you can try forgetting the network and reconnecting, checking for network updates, or even resetting your network settings on your phone.
Turn Wi-Fi on in the upper right corner to see available networks
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 55
Total : 368
