Lenovo IdeaPad Gaming 3 (15ARH05) Power Button Not Working After C-Cov
I replaced the C-Cover (5CB0Z37650) on my Lenovo IdeaPad Gaming 3 15ARH05 because the power button seemed stuck. However, even after replacing the entire keyboard assembly, the power button is still not working.
I can use the keyboard to type, so I know it's properly connected, but I still cannot turn the laptop on or off using the power button.
I'm wondering if there's any missing part? (e.g., a spring, rubber dome, or bracket under the power button)
Any advice or reference images would be really helpful. Thanks in advance!
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
It's a tactile switch and it does look like the top part of it is missing.
It is a Diptronics T3BL-03-Q-T/R and they're available from here
Here's the datasheet for the switch and here's a zoomed in image (sorry about the blurred image) that shows what it looks like.
It looks like it is soldered onto pads on the motherboard, one in each corner, so you may be able to remove/replace using a hot air gun perhaps.
Note the arrowhead on the board. That denotes the location of pin 1 of the switch.
According to the schematic pins 1&3 are connected to each other (tracks on the board under the switch) and connect to D1 and pins 2&4 are connected together and go to earth. Make sure that when you insert the switch that it's in the right way so that when you operate it there a short circuit between pins 1&2 (and also 3&4-) - see the image on the right showing the switch on your board where I've marked the pins. Use an Ohmmeter to prove it. If you connect the switch 90° either way it won't work. It has to be orientated the correct way. Hopefully there is a mark on the switch to denote pin 1 that you can line up with the arrowhead on the board.
Same issue I faced sometimes Power button working or sometimes not and 2nd issue laptop automatically open Novo menu after shutdown laptop or restarting laptop
