milk frother severin sm 3584 Faulty fuse resistor need help
Has anyone repaired the severin sm 3584 and has a picture of the board with capacitors and resistors, because my fuse resistor marked on the board with the symbol RF burned out and I can't find anywhere data about the parameters of this resistor and it is so damaged that you can't read from it what capacitance it has. I wrote to severin but no response. Please help.
Update (02/11/25)
This resistor has 1,2 cm large
Update (02/11/25)
3 commentaires
Hi @zukzuzlowiec
It is not a capacitor, it is a resistor.
Have you tried using an Ohmmeter, to measure its resistance value at all?
par jayeff
Yes this is RF = Resistor Fusible I check but nothing results
par wojciech
@zukzuzlowiec
Has the other side of the resistor (see in last image you posted) got less damage on it?
I don't think that RF means resistor fusible.
Usually fusible resistors are simply marked as F the same as a fuse.
Also given what I think are the colour bands on the resistor, i.e. Yellow, Brown, Black, Gold, Yellow and wattage, (the power rating value is based on its size in the image), that it is a 41 Ohm 0.2% 0.5W resistor.
Perhaps try the method shown in the link posted by @oldturkey03 below and check if you can hopefully get an idea what its value may be
par jayeff
