Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A1418 / EMC 3069 / 2017 / Processeur quadricoeur i5 à 3,0 GHz, quadricoeur i5 à 3,4 GHz ou quadricoeur i7 de 3,6GHz. Sorti le 8 Juin 2017.
Identify circuits on logic board - bumped while ugrading
While disassembling my old 2017 iMac for a SSD upgrade I accidentally bumped the logic board and 2 small circuits got damaged. I completed the upgrade and now when I'm trying to boot it up the screen stays black and only the first 3 diagnostic lights on the logic board light up. would these circuits be the reason for that or is there some other problem as well?
heres a picture of the damage
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
@kyler61164 looks like your board is a 820-00629 (if not let us know ASAP) and there are no boardviews available for this. Some sections on the 820-00597 are somewhat similar but not identical for the whole board. In the case of your components and verifying with the schematics at hand, the one marked
#1 is a 2.2µF 20% 25V capacitor in a 0402 package
The next one is a 1000 PF 20% 25V Capacitor in a 0402 package.
You do have a torn solder pad which may complicate the repair. Scrape the solder mask a bit more so that you can possibly rebuild the pad. #1 is on the GPUCore rail and #2 is on the VReg 3.3V S5/5V S4 rail
If unsure and since you still have the components, use a capacitance meter and check the two components values. You can then resolder those or replace them if need should be.
Indice 2
1 commentaire:
@oldturkey03 Thanks! I believe the board is the 820-00597. Those capacitors will be my problem then. I don't quite trust myself with that delicate soldering, so I'll have to look into getting it repaired.
This will teach me to be more careful when disassembling computers...
par Partager
Ajouter une réponse
Kyler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 24
Total : 248
