Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en juin 2017, l'iPad Pro 10,5" remplace l'iPad Pro 9,7"
Screen black after water damage - everything else works
Hi all,
I spilled water over my iPad Pro 10.5". I tried to dry it off as good as I could, however, the screen turned black.
However, everything else works (I connected the iPad to a Mac and streamed the screen); in particular, the iPad registers touch inputs.
My question is whether any of you have any guesses what could be going on. Is the iPad repairable without changing the screen and do you have any guesses what is causing the screen not to work but the touch to work?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi @michaelbur67062
Water damage can cause unusual things to happen with electronics.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the tablet's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your tablet and then disconnect the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is the ifixit iPad Pro 10.5" repair guide that may help.
If this process seems too daunting, take your tablet to a reputable, professional mobile phone or electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Indice 0
Ajouter une réponse
Michael Burger sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 147
